Re: tn28 flywheel removal, what am i doing wrong
That all looks good, you have to put a great deal of pressure on your bolts, almost to the point of pulling the threads, then WHACK it good with a dead blow hammer, not ***** hit, it will POP.
The amount of torque needed you won't be able to apply by holding that strap, you need a prybar between the center bolt and one of other 3 or a huge cresent on the one square of the puller, then you can pull some torque.
