TN-28 broken clutch spring
greenygreen
Hello all. you guys have been invaluable to my restoration of my tn28. first trip out this spring my clutch spring was broken from the get go. So i am currently running on half of a spring with no clutch anyways.... does a pinion spring assembly for a tn26 fit the tn 28, with the exception of the ear that expands the spring? all i really need is the spring but cant find it without the shaft.
HighTrim
Re: TN-28 broken clutch spring
Im sure I have one buried in the parts rooms, Ill have a look see around tonight.
I know I have this whole assembly.
nwcove
sheesh.....i get lectured if i leave my shoes on the stairs!!! lol
greenygreen
yes that would be it. jg1921@yahoo com , thanks so much.
HighTrim
My wife is VERY forgiving, lol. You should see my basement. She has to scale my spare powerheads like My Everest to get to the washer/dryer :)
greenygreen
also tomorrow i am modifying a sierra float for this tn28 . any tips? i understand to drill it to 3/32 but how to attach to pin im not sure about yet
greenygreen
yes sir but this new float isnt a cork. not sure if i can just screw into it. pn napa 18-7208
greenygreen
sierra 18-7208
F_R
Yes you can. I've done it many times. You can also cut, carve, sand & grind on it if necessary. It won't soak up gas.
