Re: Tire wear
Go to a good trailer repair facility and they can re-arc the axle for you.<br /><br />As Dakota said, the axles are pre-arced for a particular weight. As in, the tops of the tires are closer together when the trailer is empty (negative camber). Then when the trailer is loaded the axle flexes and the tires are near zero degree camber. Likewise, overload the trailer and the camber goes to possitive camber, thus wearing the insides of the tires.<br /><br />Another possibility is that the new axle is bent as in not aligned or collided with something.<br /><br />Either case can be corrected by a good trailer repair facility. They place the axle in a jig, then bend it to the proper alignment. Should cost around $100 per axle.
