Tire splits question
nc4z
I bought two new 4.80 x 8.00 tires and rims a few months ago. They probably have less than 200 miles on them. I noticed yesterday there are splits in the sidewalls. One tire has several and using a straight pin I found that one is 1/8 in deep. The splits run perpendicular to the rotation. Some are over 2 inches long. Does anyone know what the cause could be.<br />Thanks
Ross J
Re: Tire splits question
You don't say what size rig they're on but splits could suggest there too much weight. <br />Do the tyres flatten out a lot? Is the inflation OK, 40lbs or more? <br />Is the suspension OK?<br />Otherwise you could have a fault, either way the tyre agent could be your most helpful assistant.<br />Ross
D
DJ
Guest
nc4z,<br /><br />If the sidewalls are split, those tires have had it. They're not safe.<br /><br />I agree that underinflation was probably the culprit.
nc4z
Thanks, I thought maybe low air could be it. I called ther Mfg and theyre send me a couple of new ones.
TOMMYM
The sun is your tires biggest enemy.Under-inflation is second. If you want them to last,<br />rinse them off after use, and keep them in the shade or cover them..................TOMMY :)
