tire pressure
verojim
on my tires it says 70 lbs cold is that correct, it sounds like alot of lbs.tire size 20.5x8.0 - 10
CATransplant
Re: tire pressure
Inflate your tires to what it says on the sidewall. These are not car tires. They are designed to run at the inflations stated by the manufacturer.
The tire maker knows what pressure the tire is designed for. A lower pressure will make the tire sidewalls more flexible, which will cause excess heat, which will lead to shorter life and, possibly, tire failure.
Bigprairie1
Re: tire pressure
70 psi sounds right.
I'm just in the process of getting my vehicle ready for a holiday trip so I've been checking my tire pressures as well.
I've running a 1/2ton extended cap pickup w/ 16" tires and they state 65psi cold....so you're not far off that.
Anything over 50 psi is a good idea in my opinion. If you can do 70 psi I'd do it...plus you'll get a little better mileage (less rolling resistance).
Like CAT said tho'...follow what the manufacturer says. We are just giving you some feedback and not trying to replace their info.
kenmyfam
Re: tire pressure
Whatever it states on the sidewall is what you should be using. You will see many people that did not follow this at the side of the road scratching their heads. Under inflation = over heating = tire failure.
tashasdaddy
Re: tire pressure
under inflated tires, cause excess wear on bearing, and the tires. #1 cause of tire failure.
