I am a long time owner of fiberglass hull ski boats. Loading them on a typical "drive on" trailer is easy, as they typically correct themselves as they are loaded. Just drive them on. I just pruchased a new Tahoe 24' pontoon boat and loaded it on a bunk style trailer for the first time. Wow what a pain!!! The trailer is too submerged near the rear to tell if the pontoons are aligned with the bunks, but if I pull the trailer out of the water to see if I am aligned correctly I can't get the boat up far enough for it to load (without a lot of cranking and "dragging" it up on exposed bunks which are out of the water).
My first time loading, the trailer was too deep and we actually had a pontoon over one of the center "guides" (on the inside/between both pontoons) and dented the pontoon as we tried to drive the boat onto the bunks. (Should I be worried about removing the dent?)
Any advice/guidance/suggestions for loading a pontoon on a bunk style trailer would be greatly appreciated.
Thanks,
Shawn
Thanks,
Shawn
