Tips for converting an old roller trailer to bunks?
gunner1
Probably going to convert my crappy roller trailer to bunks this spring before the srping striped bass run starts and was hoping for some tips/advice. Can it be done for not much over $100? Here's the link to photos I posted previously of the trailer: http://forums.iboats.com/showthread.php?t=225715
tashasdaddy
Re: Tips for converting an old roller trailer to bunks?
some where in that price range. if you look at the pictures of my trailer in the other thread, that trailer was a roller trailer. the back bracket was bolted to the existing bracket of the trailer. for that boat i would use flat bunks, as i did on mine.
gunner1
Should I get new brackets as well? Would you recommend the six foot bunks? Can the transfer be made with the boat still on the trailer if I do it one side at a time?
tashasdaddy
i like to just slide my boats off in the yard, if they are not too, big. it is much easier and faster. new brackets, yes.
1/you can lower the tongue to the ground. i would get some 6x6 or old railroad crossties cut the +- 12 inches, now block up the transom.
2/ Raise the tongue of the trailer the back of trailer will drop away from trailer. this is the tricky part. between the cross braces of the trailer block the keel lower trailer, boat will be suspended on the blocks.
(you can now work on trailer or boat, or continue to remove trailer completely.)
3/ pull forward, lift bow again, and reblock i a different place. repeat until trailer is out from under the boat.
4/ to reload, just reverse the procedure.
if you were just working on the bunks, or painting the bottom. you could just do the first 2 steps.
gunner1
D
DJ
Guest
There are several on line trailer parts stores. Just do a Google search for "Trailer Parts".
The bunks will cost more in shipping than they are worth. All you need is "2X4"s and indoor/outdoor carpeting.
The brackets that hold the bunks to the brackets are just flanges. They're relatively cheap.
I believe you have an aluminum boat. Keep the keel rollers in place.
tashasdaddy
i use 2, 1/2 inch galvanized bolts. for each bracket. you can also check here. good people "http://www.championtrailers.com/" i have order many parts from them.
gunner1
I guess my biggest concern is that I don't really know how to mount/assemble anything. If someone could provide some detailed close-up pics, it would really help.
tashasdaddy
took these just for you.
keel roller and front bracket
rear bracket, use to hold rollers
middle bracket
front bracket
these are all on one bunk about 7 feet long. you have to make the lumber work with your mounting places.
gunner1
Wow, those are really great pics! That realy helps clear some questions up. What length bunks would you recommend for my 16' aluminum boat?
D
DJ
Guest
That all depends. Just remember that the bunks should stick out, past the end of the boat, at least 2".
Six to eight footers should suffice, depending on your trailer cross bracing.
gunner1
Should I use 1/2" or 7/16" square ubolts for attaching the brackets to the trailer frame?
tashasdaddy
i have always used 1/2 inch galvanized, with lock washer. as DJ said, extra length, i did this so i could swap trailers when needed.
cc67
Looks like you got a porch swing in that boat :D
