diskord
- Jul 14, 2010
- 23
So I have an old '68 Merc 1000 outboard that I am trying to "dial in" on my new (to me) boat.
The old owner had the outboard set on the 2nd from the bottom trim setting (the outboard just has a bunch of holes that I run a bar through, and then the outboard rests on the bar). Everything I have read on trim is to adjust by "feel" but as a first time boat owner it is hard for me to know what I am supposed to be feeling, and since that thing is so heavy it isn't the most fun to lift up and down constantly.
What I am wondering is what some "guidelines" are for setting trim. For example, I put a level on my trailer, and using my trailer jack I got my trailer perfectly level, so in theory the boat is now level as well (although I notice this makes it pretty bow high, as the top of the boat isn't level with the bottom of the boat). Anyway, with the boat level on the trailer, the prop is pointing down at a 10 or 15 degree angle. Does this seem right? Everything I have read says that I want to be bow high when cruising, and not "knifing" in to the water.
At full throttle it isn't porpoising, but the steering (not power steering either) definitely gets "heavy" but I don't know if that is how it is supposed to feel or not.
Here is how it looks:
(note, the driveway is slanted down but I have the trailer level, and the house should be level [I hope!] so I tried to use it as a guide for vertical level out of the top of the motor when taking the picture) The boat is sitting stern high from the perspective of the top of the boat, but the bottom of the boat, as sitting on the trailer, is level.
