timing
mr roach
i replaced the timing belt on my early 70's merc 115 inline 6 i marked evrything and do have some mechanical experience but it seems i either have the timimg off a bit or my carbs are acting up. Can someone give a link to how to time this engineso i can eliminate that as the cause of my problem much appreciated
AllAboard
Re: timing
Did you find TDC and line up your distributor pulley "arrow" with your timing mark? You do that initially, then follow the above link. Good Stuff !!!
