Help me.plz<br />I have a yamaha pro 50! it is in running order except the timing seems out of whack by 15 degrees. I am having a probl;em with the idle and have cleaned the carbs and jets. I seem to be able to adjust the timing using the electronic black box mounted on the side of the engine. I have inherited the problem from someone tinkering with the motor. also the lift works intermittenteley, can someone help me out as to how to adjust the accelerator to the timing ratio.<br />the lingage isn't very long thus am confused to hell. Thank a bunch!<br /><br />
