Timing Woes!!
gustafsonerik
125 hp 88 force prestolite ignition..Im trying to set the timing on it..on the flywheel i see a mark..tdc then next to it on the left i see another three little marks i'm assuming 32btdc.. This is my question??? At WOT and pointing the light the tdc mark lines up with the arrow on the powerhead..Is this correct???or should i turn the screw until i see the other 32bdtc mark line with the arrow..Is this the correct way???i really need help thanks Erik???
Unbalanced
Re: Timing Woes!!
At WOT you should be seeing the middle of those three marks (28,30,and 32 deg BTDC). At idle you should be at TDC +- 2 deg.
