Timing wheel indexies
Londog
1992 175HP Johnson Fast Strike J175GLENC. Have misfire out exhaust. Trying to do test with induction timing light to check timing wheel indexing. Tried two different timing lights cannot get them to flash at all. Installed new OMC CDI Suppression spark plug leads (grey). Attaching light red to + battery post and black to ground on block, induction clamp around plug lead- no flash.
Honorary Supreme Mariner
Timing on these motors rarely goes out of adjustment.-----Are you sure it is not a " lean running " issue that is causing the " misfire " from the exhaust?
Londog
Timing wheel indexing
1992 175hp Johnson faststrike j175glenc. Have misfire out exhaust. Trying to check timing wheel indexing as per service manual. Have new omc CDI suppression spark plug leads (grey). Attaching induction timing light wires red to positive battery post, black to ground on motor, induction clamp on spark plug lead. Tried two different lights. Getting no flash from timing light even though motor is running.
Rustywrench
The timing on this engine is not set with a timing light. A special tool was made for it. A timing light can be used, but you have to be aware that the OIS (Optical Ignition System) is sensitive about a strobe light being shined under the timing wheel. Since the igntion is controlled by a light any interference confuses the signal. Now for your timing light problem. Did you try the light on another cylinder? (Just to see if it will operate)? Try turning the timing light pickup over. Sometimes it is hard to pickup the signal with the suppressor wires. (Could be #1 wire is not firing?) if you get that corrected it is imperative that you shine the light straight down at the wheel. Not at an angle. There is a reason that this engine has that little top cover over the encoder & EET. It needs to be dark under there for the system to work properly.
Dont forget this engine has to have Champion spark plugs only! QL78YC. No other brand will run properly because of this ignition system.
Tim Frank
I guess he is sure.....
I wonder if this is a new problem or came with the motor?
Basic troubleshooting tests done?
Londog
When she misses (about every 8 seconds at idle) I get a puff of light smoke out exhaust-- so something too lean? All new fuel lines, double checked connections. New fuel filter. New carb kits. New plugs champion ql78yc @.30. New plug leads. New vro last summer. New thermostats and starboard heat sensor. New exhaust to power head gasket. Pulled heads to look at tops of Pistons-- a lot of carbon but after cleaning off no holes. Was surprised at amount of build up on tops of Pistons having done a decarb early spring. Did spark test with inline tester?? Thought if I could index with timing light maybe maybe rule out crossfire? Checked timing with johnnyrude faststrike easy timer came up with 6 degrees atdc for slow and 19degrees btdc for max. Compression is borderline?? 90,90,90,85,78,78 one thru six. I've had motor 3 yrs started coughing in reverse this spring and got worse fast. Sorry for writing a book but hopeful the more info you have the better. Thanks for the help!!
jakedaawg
You have low compression . Needs to be addressed.
racers comment about a lean pop is now even more relevant.
were the throttle bodies serviced? That's where the lean pop comes from on these...
Londog
Cleaned throttle body orifices with spray Johnson evinrude engine tuner. Throttle plates were reset with sync and Lync. Did not soak throttle body. Did not remove core plugs, should I? Installed new gasket between throttle body and intake manifold. What about the throttle body causes lean pop?
Rustywrench
I would pull one plug wire at a time with the motor running. (Ground the boot on a head bolt.) The skip should go away when you get to the cylinder effected? Your compression numbers seem low, but could be a goofy gauge? The one cylinder 85 sticks out because it is different from other top 4. The two bottom cylinders will be lower because of staggered combustion chambers on these motors. See if the 85 cylinder happens to be the one that makes the spit go away when unplugged.
If you have one changing the sensor under the encoder wheel might give some results. Those things get cloudy eyes and can give problems.
Does QuickStart work normal and disengage after warmup?
Tim Frank
When she misses ...... spring and got worse fast. Sorry for writing a book but hopeful the more info you have the better. Thanks for the help!!
Never too much info. Excellent post....would have been a great first post. :)
Let us know how you make out with post #9 suggestions.
Londog
Fired her up ( starts great) waited till quick start kicked off @ 800 rpm and started pulling spark plug leads and grounding to head bolts. 1,2,&3 all dropped rpm but the exhaust pop stayed pretty much consistent. #4 did not affect rpm as much and exhaust pop ,although still there ,was less frequent. I have no idea how to interpret that results. I also did a vacuum test between bulb and fuel connection at motor. Vac gauge read @ 1 and had a huge air bubble in clear tubing. Manual says I'm suckin wind or I mean air. Will redo all connections in new fuel lines. What is hiding behind the throttle body core plugs? By the way it's great to be able to ask questions about a faststrike 60 degree looper without seeing their eyes glaze over thanks!
Rustywrench
Just so we are in agreement the starboard cylinders are top to bottom #1, #3, #5 & the port cylinders are top to,bottom #2, #4, #6. By any chance is #4 the cylinder with 85 lbs of compression? Worried you might have a piston/cylinder/ring issue. Maybe a score in that cylinder? It's easy enough to look on this motor. The orings do not have to be replaced after inspection. Just some high temp RTV around the water casting ports & put the head back on. Torque is 20 lbs. sequence is numbered on head. Let us know what you see or send a pic if possible?
Londog
Been hunting air leaks. Jakedawg mentioned throttle bodies causing lean pop. If I pulled carbs and throttle bodies back off what should be done to throttle bodies? Manual is pretty vague. Thanks!
Londog
Replaced coils and power pack. Air leak tests with clear tubing. Did vac test before VRO pump- 1.5. Pressure test before fuel manifold- fluctuated from 1# to 4# and kept fluctuating for 5 min idling and up to 1500 RPM on muffs. During the testing and searching for air leaks had something happen that has me scratching my head. I had disconnected oil line to VRO pump and had placed piece of clear tubing in oil line.Had gas line connected to remote gas tank with 50:1 mix in it. Had clear tubing between fuel nipples next to vapor separator and fuel manifolds. TheVRO oil pump had lost prime and did not pick up from oil tank. I thought no worries since I was hooked up to 50:1 remote tank. After several minutes the exhaust misfire I've been chasing for a month stops! Hope!! About one minute after I noticed the miss had disappeared, the no-oil alarm started sounding off. Having never heard this alarm before and not realizing it will sound off if running from remote tank - I shut her down. After deciding all was ok I plugged the oil line trying to recreate scenario . Fired her up, the misfire returned immediately. The no-oil alarm started sounding after about 4 min. Motor continued to misfire out of exhaust. Combining this occurance with the amount of oil showing on #5 piston top ( see pics)and head after only running an hour since being cleaned- does this indicate anything? Pulled heads back off for pics- wish I hadn't cleaned carbon off before I started this thread. Can feel very slight scoring in one spot in #6 cal wall others are smooth. Any one doze off yet? Thanks a bunch!
Rustywrench
If you decide to rebuild this engine have the block pressure tested before you continue. Don't know where you are located, but Jays Block Shop in Sparta, TN can do it for you. 931-808-0814.
Londog
Are you seeing something in pics to alert the need for pressure testing or is it just a good idea
Rustywrench
Just don't want you to rebuild & discover you have a water leak on #1 cylinder. Common problem on these motors from early on till around '97 models. Casting flaw. Opens up after years of use.
