can someone tell be the setting for timing a vortec 4.3 litre for 89 ocatane. Thanks
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #1 can someone tell be the setting for timing a vortec 4.3 litre for 89 ocatane. Thanks
H HalfFish5087 Petty Officer 1st Class Joined May 30, 2012 Messages 278 Jul 11, 2013 #2 Re: timing setting Provide serial # or engine model #.
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #3 Re: timing setting The problem is i rebuilt a 95 and added vortec heads and intake and a holley 4 barrel carb
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #4 Re: timing setting but it is the stock mptor from a 95 sundowner with the added vortec accesories
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 11, 2013 #5 Re: timing setting What ignition system? That's the important thing here.
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #6 Re: timing setting i know its electronic. i think it says like epi or something. im headed there now and ill post what it is
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #7 Re: timing setting its electronic ignition
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 11, 2013 #8 Re: timing setting jay127 said: its electronic ignition Click to expand... I know that, which one? Prestolite BID or Delco EST?
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #9 Re: timing setting Sorry to sound dumb but how do I tell the difference. Its all stock from a 95 fourwinns sundowner with a 4.3.
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 11, 2013 #10 Re: timing setting You should have the Delco EST. Here is how to set it. 1? BTDC - w/86-88 AKI fuel, 6? BTDC w/89 AKI fuel or higher. View attachment EST Timing.pdf Specs, timing and fuel requirements 1? BTDC - w/86-88 AKI, 6? BTDC w/89 AKI.
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #11 Re: timing setting Thank you very much. Hopefully afte I figure out the carb vacuum ports and time it it will run properly. Thanks again
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 11, 2013 #12 Re: timing setting jay127 said: Thank you very much. Hopefully afte I figure out the carb vacuum ports and time it it will run properly. Thanks again Click to expand... What vacuum ports?
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #13 Re: timing setting There's one on the left and one on the right. The shop never hooked them up. I Oates pics in another thread
J jay127 Seaman Apprentice Joined May 17, 2010 Messages 47 Jul 11, 2013 #14 Re: timing setting http://forums.iboats.com/volvo-penta-i-o-inboard-gas-engines-outdrives/carb-question-616131.html
