levittownnick
- Jul 2, 2003
- 789
What is the typical maximum rpm a xenon type timing light will work to. Note 2-cycle engines fire twice the 4-cycle rate.
Thank you.
Nick
Thank you.
Nick
levittownnick;n10481928 Note 2-cycle engines fire twice the 4-cycle rate. Thank you. Nick[/QUOTE said:Depends on the engine. Most small 4 cycle engines with a magneto ignition fire every crankshaft revolution. Once at the top of the compression stroke and once at the top of the exhaust stroke. To your question, at high RPM it may appear to not be flashing but it still is.
Mike
