blacklab75
- Apr 25, 2009
- 12
I've been having problems with my 1996 Alpha 1 LX 3.0 Merc. so, I decided to look at the timing. I have the Delco Est ignition and I adjusted the timing as per instruction of the service manual to 1 BTDC and the engine seemed to be idling better.
However, when I shut off the engine/removed the jump wire and went to check the timing it's still reading at 1 BTDC, it should be reading 12 BTDC. When I thottle up to 2200 rpms it should be reading 23 but, it's only reading at the 8 mark.
What could be causing the timing to fail to advance? Or do I need a special timing light that has that comes advance feature?
