This is my first post on iboats although I've spent hours reading other boater's questions and answers. I have found this to be a great source of information. This is my story and I will try to be brief. I live in upstate New York and do my boating on the fulton chain of lakes. I purchased my first boat 5 years ago a 1985 baja 190 sunsport with a 5.7 mercruiser(mcm 260) and an alpha 1 outdrive. I was told that the motor had recently been rebuilt using some performance parts. Just looking at the top it had and edelbrock intake and carb and a msd blaster coil. The rest of the accessories i.e. thunderbolt IV ignition, distributor, alternator, power steering are all stock. When I purchased the boat I was not very mechanically inclined so I left the service to a friend of mine who had attended MMI. He did the winterizing and necessary parts replacing (water pump, gimbal bearing, ect.) Boat season is pretty short up here and I probably only put on 50 hours per year. Boat always ran well, never started or idled well, but when she was going she was going fast. End of last season motor gave up the fight. I limped in, and after having the trailer serviced ($300), I towed it to the shop the previous owner stated had done the last rebuild. They told me they had never seen the boat before but would try to diagnose the problem. They pulled the plugs noticed that #4 electrode had been hit, looked in the plug hole with a camera and told me the piston had a missing piece. This diagnosis cost me $200 and was told it would be another $600 to pull the motor strip it down and determine what I need to fix. Then cost of parts to fix and cost of labor to reinstall motor in boat. Not wanting to put anymore money into it at the end of the season I towed it back home. Soon after I decided that I was sick of paying other people to work on my stuff and what better time to learn than now. I purchased an engine hoist, engine stand, tools, several books and started in on it. I pulled the motor striped it down and to my pleasant surprise found 8 good pistons when I pulled the heads. I had sucked in a pea sized piece of the intake valve on #4. This piece had left several very small divots on the top of the piston but no marks in the cylinder walls. I took the heads to a good machine shop and per their recommendation had all intake valves replaced. I followed the books closely, put everything back together, reinstalled motor and again to my pleasant surprise the motor runs great. By this point your probably wondering what the question is. Well in my case with more knowledge and a better understanding of how things work comes more concerns. I now believe that this motor has a slightly hotter cam in it. When setting the timing at idle the motor runs well around 14-16 degrees BTDC if I try to retard it back to the 8 degrees BTDC the stock motor calls for I have to really compensate with the idle adjustment on the carb to keep it running which is just loading it up. I've read most of the posts regarding the thunderbolt IV ignition and determined that there is no base mode for setting timing with this ignition. My first question is, with the information I've provided is my assumption of a hotter cam logical? I've been told that a hotter cam will usually have a timing that is more advanced. It also has a bit of a roll to it at idle. My second question is if I'm setting the timing a idle and it is 6-8 degrees more advanced than stock what will this do to the timing at WOT will it be to far advanced and cause a lack of power or worse? Thunderbolt IV advances timing 22-26 degrees putting my WOT timing at +/-40 degrees BTDC is this OK? Well that?s it for now, so much for being brief, I just felt like a little background might be needed. I have many other questions but I'll save them for another post
Thanks for any help that you can provide I'm still learning and love it.
