rogueflyfisher
- Aug 6, 2005
- 5
16 foot fiberglass boat with Merc 500 - 50hp. Boat doesn't get enough power wide open to get on plane. Runs great at idle, and slow trolling and medium speeds.<br /><br />A couple of notes: the engine won't shut off until you hold the choke down after shutting off the key.<br /><br />Also, when you take the spark plugs out after running, the plugs are a little gunked up with oil.<br /><br />Also, it's not the fuel pump, since when you pump the bulb it doesn't increase the speed at all.<br /><br />Does this sound like a timing problem ? Or something else?
