timing advance linkage
rlouis5
I have a 1979 Johnson motor 175 hp that has a broken timing advance linkage...it is a short rod with plastic balls at each end...where can I purchase one of these? I cannot find this part and I am uncertain what the part is named or what the part # is...thank you
Robert
rlouis5
Re: timing advance linkage
no I do not have a model #.. The tag is gone from the engine
Joes_yj
Let me know if you find one I need one as well
emdsapmgr
Likely you need a spark advance rod. 320950. That original part is NLA. Replaced by 308743. Stocked in all Bombardier warehouses. About $ 4. The ball joint 313703 is NLA, but stock is avail on superceded part 395448, about $ 7.
