Timing a 1986 125 Force out of water at cranking
iwaterdave
So I saw a video on how to time a motor out of the water. Says to time it at cranking speed at 28 degrees and once in the water will be at 30 degrees. I did that and the timing marks are really off but is lining up with the solo line on the flywheel. Is this correct? Or should I make some major adjustments to bring it closer to the 3 marks on the flywheel? Video also included...
tommarvin
Ensign
IDK, our factory service manual explains that perfectly though.
I have never timed our 125hp,but if it says to time in the water ,I would.
iwaterdave
NEVERMIND!!! I did not have it in W.O.T. Cant believe I missed that step... :(
