Aux Shaft speed-o-gear worn out. Replaced with new shaft and new speed-o-gear.<br />Set up timing per instructions in manual, crank shaft at 0 tc, overhead cam pulley mark aligned, distributor rotor pointing to #1 plug wire on cap.<br />Runs rough and lopes, can get no RPM <br />Turing distributor makes no difference.<br />Installed new plugs, plug wires, DIST.cap, points, rotor, and condensor.<br />Everything is set right but won't run.<br />Please give sugestions. Help, Help
