MASTER Brian
- Mar 26, 2006
- 738
I have 3 batteries, 1 is for the accessories and cranking the engine, the other two are for my trolling motor.
The trolling batteries are about 6-7yrs old and don't seem to be holding a charge, so pending a test, they are most likely being replaced in the next month or so.
Is there anything special I should consider to get the best bang for my buck? Do I just get the largest deep cycle battery that will fit in the cavity or is there more to it? Most likely I'll go with Walmart batteries, because that's what these are and I've had good luck with them. These are 72mo batteries and they've lasted well over that. The ones in my vehicles are from auto stores and they are crap, but I'll gladly listen to brand recommendations.
Also, if the crank/accessory battery needs replaced, do I once again buy deep cycle or what? ....should it be the largest that will fit?
I question this, because I've seen a few diagrams that seem to spell out different batteries for trolling vs. cranking.
Motor is 150hp Evinrude, if that matters at all.
Thanks!
Thanks!
