So it's time for a new prop and I need some guidance as I've never selected a prop before.
Here are the vital stats:
Boat: 18' Ebbtide ski boat (1075 lbs dry / ~1475 lbs fully loaded)
Motor: 150 hp Mariner Mag III
Current prop: p/n 48-78122-21 (I think this is 21 pitch / 16? rake / 13.75" dia) aluminum
Currently, the motor will turn ~6300-6400 RPM @ full throttle which yields ~ 55-57 mph.
If I keep the motor around 5800 RPM, then it'll run about 50 mph.
The boat has an awesome hole-shot and planes very quickly, but I know I can get more top end. I would also like to stick with aluminum due to cost.
Based on these numbers, what do you think I should go with?
