I just tried to refill my tilt, it said to use SAE 30W, so this is what I did. Problem is I always need to assist the motor for it to work. Once it reaches half way up it starts to work on its own. I do not need to assist it much but it will not go on its own. The tilt is with a 1963 Johnson Super sea Horse 75hp. The motor is running, and I can't seem to get more oil in. I have pumped the motor up and down as much as I can. Could it be possible that the manual release is letting out air. Please help if you can. Thanks
