tell us more… does it buzz, click ,wirl, stays silent, hesitates jams did it ever work on the other boat ?? ….. have you done any voltage checks anywhere, how are you with a volt meter ??
It works if i apply direct power up and down. The switch on the throttle just up, unless i swap wires. I hooked a new switch up to the wires at the throttle, still just up.
80s Johnson 88hp, 98 Aquasport
With the Trim Switch wires unhooked in the Relay Box, attach the Ohm meter to the Common and to the Down wire, Close the Down Switch, and watch the meter
Thanks for everyone's help, tracked it back to the switch, anyone know who might have the correct switch? I am looking online and don't find one that looks the same. It's kind of contoured or should I just put one in the dash?
