tilt/trim
Senior B
Hello. Yesterday 5 min from home, my motor tilt trim stopped working. It does not go up or down I have a 2010 5.7GXi-JF with a DPS-A Out drive. I have not started to T/S it yet but am curious as to the location of the 40Amp circuit breaker that the manual mentions. Thanks in advance.
Renny76
On my boat the fuse is next to the relay, which is right next to the hydraulic pump.
Senior B
Have trouble shot this to it being the motor. I tapped on the cover with screwdriver while my assistant held the trim switch. One tap and it started working and has until yesterday. Tapped again and all good. My question is: Can you get just the orings and gaskets to remove the cover and lines? I believe if I take it apart and clean the contacts I will be back in business. If these can be reused, then great. Hoping someone here has done this and can comment. Thank you in advance.
Donald0039
I had a trim motor rebuilt by a shop that does motor rebuilding. They did a great job.
