Tilt trim works no gauge
danzoot911
My tilt trim work fine on my boat, but the gauge does not register. Any ideas? I have a 1985 40hp envirude. Thanks in advance
Hooty
Re: Tilt trim works no gauge
Either sending unit, gauge or loose connection. The sending unit is a varible resistor so you can check it with a vom. Connect ohm meter to the two leads from the sending unit and see if resistance changes smoothly when moving lever. The gauge is nothing more then a volt meter so you can check it with your volt meter. If they both check out o-k, start looking for a bad connection.<br /><br />c/6<br /><br />Hooty
danzoot911
Hooty thanks for the help, but where would the sending unit gauge be?<br /> THANKS
