stickyricky67
- Apr 25, 2004
- 10
Hi, <br /> I own a 1984 140hp Johnson O/B. The problem I am having is with the power tilt/trim. From the trottle I can get it to go down but not up. At the relay box when I switch the blue and green wires it will go up. I believe that the switch is bad in the trottle. Is that an easy item to replace. And how can I be sure that is what it is. Thank you for any help.
