Tilt/trim wiring question
spidc60
My boat has an aftermarket tilt and trim. The maker on the side is CMC. There is one switch at the front of the boat, but none on the back. I would think that I could splice into the wires going back to the unit and add a switch so that I could use it from the rear of the boat. Anyone know how I could make this happen?<br /><br />Thanks
chuckz
Re: Tilt/trim wiring question
You should be able to install a second switch in parallel with the first.
