Re: tilt trim remove 200 1986 yamaha
Not familiar with your motor but it should be simple. Lock the motor up, remove the cir clip from the big pin that the top of the ram is attached to and push it out. Remove the bolt , either side, from the bottom pin and push it out. Bushing are plastic so there is no problem with corrosion. FRED
