Tilt/Trim Problem on 40 HP Yamaha
hondajohn
I have a 1995 40 Yamaha that will not trim up while the motor is in gear and running over about 1200 rpms. Other than that it works fine. Is there a lockout or a switch somewhere that may be bad.<br />Also, I removed the oil fill for the tilt unit thinking that it might be low on oil and I can't see how to add oil to it. Is there a special fitting that you have to use.<br />Thanks
Jammu
Re: Tilt/Trim Problem on 40 HP Yamaha
Is your engine with trim or tilt ??<br />What is the type ??
hondajohn
Not sure what you are asking me? The problem is with the trim unit.
