Re: Tilt & Trim ? on 87 50hp Johnson.
First thing to do is check your manual release screw on the starboard side of the T&T unit. It will be a large slotted screw. Make sure it is tight. Might even put some liquid soap/water mixture around the screw to be sure it's not leaking. If this is OK, raise the lower unit up and remove the fill screw at the top of the T&T. Top off the fluid as nessesary. Replace the screw loosely and cycle the unit up and down 4 or 5 times. Check the fluid level again and top off. Repeat this one more time and then tighten down the fill screw and see if it helps. If not, it is an internal problem with the T&T unit and will require dissassembly to repair.
