The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
CaptainPuget,The tilt /trim oil is equivelant to power steering fluid, however I recommend getting product specific oil from dealer or supply house that is intended for use in your unit.
Some t/t units use 30 weight motor oil. My '95 Force does. Most other manufacturers have gotten away from this. Best to provide specific make/model/year info on your motor, or contact a local dealer with the same info.
CaptainPuget <br />If your talking about your Johnson T & T, then you would use power steering fluid or better yet, you can get T&T fluid at Walmart or your dealer.
Thanks all for the responses. I was considering topping off the reservoir with something I had in the garage. Based on the responses I'll just wait until I can get to the dealer and make sure that I get compatible stuff.
