tilt/trim motor on 45 mariner
Cigaretteman
Just got the motor off and the drive going into the pump looks to be an allen wrench shape and in the range of a 5/32 maybe. All the motors on line show a paddle looking drive on them. Anybody know what motor may fit this or is there an update you must do. Thanks you all Im just a bit confused here. Motor is suppose to be an 80's model ser#OC121374.
Prophammer
see attached - does it look like what you're talking about?
  • us cat 90-6403 0B110789 and up.pdf
Cigaretteman
Yes sir, thanks for the cutaway Prophammer I will keep that on file. I got it just using good old common sense. Had to remove the right side motor mount and got right into it. put the new style motor on it with the new style wiring where you remove the solenoids and replace them with breakers. pretty simple and YEA it works again. had to shorten the 3 screws that mount the pump to the motor but otherwise was a pretty straight forward and easy. Thank and blessings to all.
