Tilt/Trim issuesi with 1989 Force 125 Outboard
Deuce9
Hi Everyone. Im a fairly new boat owner and recently purchased a 1989 Bayliner Capri with the Force 125 motor. I only had it a couple days and the tilt started to act up. It now, wont move or sit up. It falls to lowest position. The relays were replace recently and I can hear the motor going. It just wont move.
Any advice would be greatly appreciated
Thanks so much
bentle
Re: Tilt/Trim issuesi with 1989 Force 125 Outboard
Check for water in the oil at the pump. Also make sure pump is full of a good marine grade power tilt/trim oil. Pump may need a rebuild but check other first. Also may need to bleed air out of system.
