Jonh Davis
- Sep 10, 2005
- 5
I have a 1981 60hp Mercury outboard. The problem is there is a serious leak coming from a hole on the side of the bottom plate between where the high and low pressure hoses connect. It seems to be a machined hole not a crack. The pump leaks when you put in oil. It doesn't have to be running.
