Hi,The tilt and trim on this motor isn't working correctly. It trims up fine the goes to tilt as it is suppose to. It will remain it the up position. When I tilt down the trim pistons go in first and then the tilt piston brings the motor down. If you stop anywheres after Half way it will bleed down. If you run it down all the way it will run down fine. If you trim it back up it will trim fine, and hold. On occaision the trim pistons will come out to meet the down movement but it doesn't seem to slow to trim mode?<br />It was very low on fluid and it was filled IAW the manual. It was run several times up and down. anybody have a clue? It is a internal power trim type.<br /> thanks steve
