tilt/run pin repair
Dave512
Hello - this is my first post. I did not see anything on this in the search.<br /><br />I have a 1996 Evinrude 25HP 2 stroke, 20" shaft, electric start and the manual tilt/run pin on the port side has come out. The pin does not appear broken and it has a flat on the last 1/2" of the end. When I insert back in, I cannot get back fully in as it stops about 1" out. I don't see any set screws.<br /><br />Any ideas on how to fix ?<br /><br />thanks,<br />Dave
Dave512
Re: tilt/run pin repair
I tapped in with a hammer and it seemed to stay put. There is a set screw underneath that was already pretty tight. Is this all there is to it ? <br />Lifting the motor up and down a few times, it looks like it is trying to back out slightly again. I just don't want it falling off out on the water.
