Tilt problem
frcdonsmith
Johnson 130 2000 oceanpro
Went out to run motor today and it was tilted as high as it could go. Tilt switch on throttle handle will lower and raise motor fine. After stopping. within 1-2 minutes, trim motor automatically raises motor as high as it will go.
Used switch on motor and down switch sometimes raises motor. Up side of switch works fine, but once again after 1-2 minutes trim motor raises engine as high as it will go. Any ideas on where I need to start diagnosing problem? Battery cables clean, two new batteries installed last month.
frcdonsmith
Re: Tilt problem
where online can you buy switches, i googled and all it provides is whole tilt units
