tilt problem volvo sx
pemar.s
Still not solved the tilt problem of my volvo 3.0 sx the hydrolick cilinders only comes out 17 cm pumps keep running no additional buttons and enoug oil in the pump. Who give me the solution to get to max. tilt?<br />Peter<br />netherlands
Don S
Re: tilt problem volvo sx
If the pump keeps running, and the cylinders stop moving, and there is oil in the reservoir, there is something binding either the hydraulics or stopping the movement of the drive. You could check the pressure with the special gauges the dealers have, or if this has been going on for a while with no help it may be time to see a certified Volvo dealer to find out what the real problem is.
