tilt is non-hydrolic make.<br /> tilt was working then after 1 month in my driveway it was not raiseing all the way and sounded laboured when raising only. checked battery (was fine), all cables checked and fine. leg was 25% up and when tryed to lower it to remove, tilt it stoped working, (im hopeing it just over heated and will work tommorow) the mottor that powers the tilt didnt work at all. now i can,t remove the tilt to service it.<br /> should i try to fabricate something to fit into my drill to stick in the hole to lower the the leg?<br />what should i do next ? ty
