tunnelwood
- Jul 22, 2005
- 5
Hello> I recently installed a trim tilt unit(3 wire)on my 115 (1979) before I installed it I hooked it to a battery and cycled it up and down. It worked fine. After Installation it would trim but not tilt. I drained the fluid and re-filled with the motor manually raised in the tilt lock position (loosened the manual unlock screw) . I then cycled it up and down about eight times and it still will not tilt. Could it have a hydraulic lock from runnig it flat on the bench? any ideas? thanks in advance greg
