mahoganybd
- Sep 19, 2010
- 14
Electrical problem -Tilt/Trim and more....
Evinrude 85hp 1977, 4cyl -- I was letting my motor up with the power tilt/trim and stopped for a moment to look at the motor and when I tried letting it down the swith would not work in any direction. Notice that some of the wires going to the solenoid were worned, cracked and also looked like part of the electrical connector was bad. Where can I get a wiring diagram for this engine(battery,trim/tilt switch, solenoid sec.), also how can I check the solenoid to see if its working and trim swith button, or is there a way to check the trim/tile mechanisim by bybassing the solenoid?
Also, if this is an electrical problem, could it also contribute to the engine overheating, or stalling when put into gear or throttle increased? Carbs were repaired but was told that they were the wrong ones for this model.
Any help will be greatly appreciated
