puffitu
- Dec 30, 2018
- 555
Hello
I have an arco marine 2wire tilt and trim unit which I’ve found to have a loose green wire coming out of the top of the pump housing. My question is; can I take off the housing to motor assembly to diagnose without draining the fluid?? Finally found issue which was on/off from time to time. Had a few times when the thing wouldn’t do anything then one day happened to wiggle the green directly outside of the motor and it suddenly worked, leading me to believe that there must be corrosion, breaking wire or both.
