CaptainPuget
- Sep 29, 2002
- 137
I've got a 1985 Merc 115 on a 17' Arima Sea Chaser. This engine is so tall it hits the forward edge of the splash well when tilted up. This prevents the engine from tilting up enough to engage the tilt lock so the weight of the engine is supported only by the tilt cylinder when trailering. I have been shoving a sawed off axe handle between the tilting part and the fixed part of the engine's frame then trimming down a bit to transfer some of the load to the axe handle but I'm looking for a better solution. I'm not a fan of transom savers that tie the engine to the trailer. Other than those, does anyone have any ideas?<br /><br />I'll try to post a photo so you can see what I'm trying explain here.
