tilt and trim
flatboat fishing
i have a 1985 70 hp johnston j70tlc05 will this tilt and trim fit on a 1978 70 hp evinrude 70873c ? thanks
emdsapmgr
The early trim units were a 3-wire system. The trim electrical box mounted separately under the rear splashwell of the boat. The trim box was wired direct to the start battery. Had one solenoid for the up movement and a single 20 amp fuse, like that of the engine. The later units used a different box, which was screwed to the back of the outer exhaust manifold. This is a 2-wire system. This box used two identical relays, one for up, the other for down. It drew it's power direct from the engine's main wire harness. So, parts of it should fit, others you will have to figure out where to mount the new-style trim box.
