tilt and trim
edjr
ive got a 92 dt 140 that needs tilt and trim replaced could i use a cmc pt130 its rated for 7800 lb's of thrust but its max hp rating is 130 whats your suggestions?
WillyBWright
Re: tilt and trim
I've never been satisfied with their ability to trim under full throttle. It also sets your motor back which may be a good or a bad thing. I think you'd be best off replacing or repairing what you have.
edjr
Re: tilt and trim
the original is no longer available and its the same price to put a new cmc as it is to get a used one? why do you say good or bad? whats the good points and whats the bad points of having it set back?
