Hey guys
I have a few questions on my trim limit and trim gauge senders.
I just recently replaced my fresh water hose, checked the bellows, engine alignment and reinstalled my outdrive.
Figured I would disassemble clean/grease the trim limit and gauge senders while I was there.
Good thing I did as I found quite a bit of rust in the contacts.
Anyhow here is where my questions come in.
The inside of my trim limit switch looks like 1 copper contact on either side of a circle with the center piece being a smaller circle with a contact bridge in the middle.
I cleaned and lubed everything and it appears to be operating correctly I think.
Is this switch just designed to stop the trim motor from raising the drive to high, or is it also supposed to stop the trim motor from trying to go down past it's limit(my trim motor won't automatically shut down when at the end of downward travel, normal)?
Next is my gauge sender which on the inside looks like,two raised silver contacts on either side of a circle and an upper disc with an almost half moon silver contact on one side and a silver at the top and bottom black in the middle almost half moon on the other.
My trim gauge either reads full down or full up(depending on drive position) but never anywhere else on the gauge.
Is this normal?
Possibly that is the style of gauge I have or is this the style of sender I have?
Are there even different alpha 1 gen 1 gauge senders?
I would just like to know what position my drive is in at all times not just full up or down.
I don't use the gauge for planeing, would just like to know for depth reasons in shallow waters.
89 3.0L mercruiser with Alpha 1 gen 1 drive.
Is this normal?
