Tilt and Trim help for old Johnson 75
bama
I bought a used 75 HP johnson with tilt and trim after mt 50 died, and I dont have the harnes to use for the tilt and trim. I bought a switch that had 1 blue 1 green and 1 purple wire. It said to connect the wires blue to blue green to green and purple to the battery. Does not work. Although if I ground the blue or green and apply power to the one not grounded it works. Is there any way to make the switch with three wires work! Or do I have to buy a harness?<br /><br />------------------<br />Good Fishing<br />Ray
bama
Re: Tilt and Trim help for old Johnson 75
I figured it all by myself (wow) Anyway I used two three pronged toggle switches that release after you remove your finger. If anyone else runs into this and comes up with a better way please let me know.<br /><br />Bama
JB
Good show, Bama. Congratulations.<br /><br />Red sky at night.<br />JB
