Re: TILT AND TRIM GUAGE
Yep listen to the sound of your boat & the feel of your steering, proberly trimmed boat sounds like marbles hitting the bottom of your boat & should have no steering torque, failing that you can check the grounds at guage & sender on tilt pin, grounds good use an ohmeter on the sender, if its working replace guage or throw it overboard & put a water pressure guage in the hole instead.<br />Cheers,& hope you dont mind the sarcasm but it is in my mind a useless guage.<br />But i'm sure I will get some arguements about this one.
