new_2_boating
- Apr 21, 2002
- 7
Hi, I'm new to the boating world and would appreciate ANY advice on this....<br /><br />My outboard is a Mariner 60, Manufactured in 1990 with Electric Start, Tilt and Trim etc.<br />(On a Picton 150 GTS Speedboat).<br /><br />When trying to raise or lower the OB, the relays happily click away - but there is no movement of the engine.<br />The first thing I tried was to replace the relays (just in case)...No Joy!<br />I've seen posts advising to clean the contacts and bullet connectors from the relays to the Tilt and Trim unit, which I have also tried.<br /><br />Using a pilot lamp I have checked that the power is getting down to the Tilt and Trim unit, which it is - well, as far as the actual unit behind the outboard.<br /><br />The Tilt and trim unit doesn't look worn, neither does it leak. The oil level is full.<br />The hydrolic arm seems to raise and lower without a problem in manual mode.<br /><br />Is it common for the tilt and trim unit to just stop working? Is there something else I could try? Are they expensive to replace? Please tell me theres a fuse somewhere..!!??<br /><br />Thanks in advance for any advice - I hope the above makes sense!
